It is currently Sat Aug 09, 2025 12:23 am
PostPosted: Wed Mar 29, 2017 5:51 pm
Last Name: shelton
City: Alsea
State: Oregon
Zip/Postal Code: 97324
I know that pre-catalyzed lacquer must be restricted to no more than 3 coats so has anyone tried building with normal nitro and finishing with a coat or two of pre-cat? It seems like a way to get a fast cure to avoid the long wait for normal nitro to get hard enough to polish. I suspect it won't work since the undercoats would still be shrinking but has anyone tried it?
PostPosted: Thu Mar 30, 2017 7:29 am
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
Not going to work. The harder precat will wrinkle and crack because you cannot put a harder coating over a softer one.
The restrictions on precat or post cat systems have little to do with number of coats applied. It is about keeping final working films under 5 mills after buffing.Depending on actual solids content and thickness of wet spray you will find that 7 coats is about the actual maximum.
If you want fast cure and harder finish just use a precat for the whole thing.
Brian
PostPosted: Thu Mar 30, 2017 8:24 am
Last Name: shelton
City: Alsea
State: Oregon
Thanks, this is pretty much what I expected. I tried pre-cat on three guitars and ended up refinishing all three due to crazing, swore I'd never use it again.
Users browsing this forum: No registered users and 47 guests
